Southern Minnesota signal loss? Two weeks of oddities | SatelliteGuys.US
snissen
SatelliteGuys Guru
137
85
southern MN
Between 9:00 and 9:30 pm CST Tuesday night, during the President's unending speech, I lost all my local Twin Cities channels suddenly. On the guide, it looks like I lost all satellite-provided channels. Since my Hopper 3 is connected to my Internet service, I still have all the streaming channels, though I had to invoke the "automatic backup" feature manually.
I assume this is a weather-related event, because that's about the time when today's rain changed over to snow. But I've seen very, very few snow outages in my many years with DISH. Is anyone else in southern Minnesota experiencing this outage?
Now, about 4 hours later, the satellite channels are still out. If the snow stops by noon Wednesday as predicted, I hope these channels will return to normal. Until then, my timers are recording a whole lotta nuthin'.
Now, Wednesday night, the guide is wonky again. The guide shows all satellite-based channels as "No signal", but my recordings of the local NBC channel seem to have worked.
Right now, when I choose a channel with streaming automatic backup, I get the network stream rather than the satellite feed. (Which apparently doesn't support Picture-In-Picture like the sat feeds do.)
At 10pm CST, I can view any of the local news broadcasts, despite the guide showing them all unavailable.,
So now I _know_ I can't trust what the guide shows me, or use it to change channels. Am I alone in this mess?
Reactions: charlesrshell
Not at all the same but I had nothing but a black screen around 5pm yesterday.Not even "you have lost signal". It was a local channel and it was wet out so I went to ESPN because it's a different satellite and has internet switchover.Still black.I was going to check out the satellite signal etc when it all came back.No reboot or anything.
If your Satellite antenna is easily accessible, take a snowbrush out to it and gently remove the snow from the reflector. Wet snow or ice that forms after changing from freezing rain is probably the worst case reception situation (other than thunderstorms), and if your backup plans are not working or cannot be trusted, a few seconds removing snow should get most of all of your reception restored.
I see your location is "Southern Minnesota". Where in general (I'm in Mankato)
Sounds like maybe the dish got moved a little bit and any bad weather will set the dish out of signal. My dad is in SW suburbs (Valleyfair area ;) and if Dish would have gone out in the last 2 days (or anytime honestly) he would have called me and didn't. He has no backup being out rural so he doesn't have Dish hooked to his internet
But every other time I've got "satellelite signal lost go watch your dvr yada yada" plus the internet kicks in on the channels where it's applicable.
And living in Vermont and having had Dish since before Hi Def I know about cleaning satellite dishes.
Actually used to have a BUD on a 20 foot pole.When snow accumulated had to whack the bottom of the dish with a broom and move before all the snow dumped on me.
  • Wow
Not questioning your expertise...I just know from decades of experience that Ku band and DBS reception falls apart when you have a mix of precipitation, especially when temps hover within a few degrees of freezing. It is a lot easier to sweep snow and slush off the dish before it gets deeper or freezes. All of the backup plans in the world can fail because they don't work in the worst weather for any number of reasons. Much less work to be proactive before things get worse than to fight with the end results or have to troubleshoot multiple things.
By last Thursday night, my guide had fixed itself, the weather was clear and warm, and TV life was fine. (Which is good, because there's no way I can reach the DISH on my two-story roof. I can't even see it clearly.)
Until late Monday night (actually, Tuesday), when all the local channels began pixelating. There's no precipitation now and it's well above freezing here in Northfield. Other than the local channels, the guide is fine and the satellite-based channels appear okay, with no messages about switching to streaming.
So once the weather calms down a bit, I think I need to make a service call, to get my antenna pointed correctly again. My thanks to everyone who offered their own reports or suggestions.
