OTHER - Splitter for Diseqc Commands | SatelliteGuys.US
OTHER Splitter for Diseqc Commands
Captain Midnight
627
425
Greers Ferry, Arkansas
Need some advice on my system. I have a BUD and 1.2m wired into a 4x8 switch. The only hiccup is my 1.2m is on a STAB H-H Motor and the multiswitch is not letting my Diseqc commands to pass. I realized I can run a separate coax directly to the STAB to give the commands from my master receiver, but I am needing to choose the right splitter to do so. Anyone have some insight on this?
I think a Spaun UniTap would be very good, as proposed here: https://forum.digitalfernsehen.de/t...r-drehanlage-kombinieren.348181/#post-7019367
You need power pass and 22 kHz pass on both ports, but the HF satellite signal preferrably not diminished ('not attenuated' is the word?).
Other splitters with power pass would work also, I think, but maybe with equal attenuation on both ports...
I myself use even a 5-1000 MHz splitter (so not 5-2300MHz) for splitting of the motor path. Works fine.
Greetz,
A33
Reactions: Captain Midnight
Greetz,
A33
Thanks for the info. Maybe I can find a UniTap here in the states. I do have a few plain 2way power passing splitters for HF until then.
Reactions: a33
AMIKO Trouble finding Satellites
