Or Recall...I like if you hit select to go full screen, you can then hit input to go back to multi view (one click). Sweet.....
This feature disappears after stand by is entered.You don't even need to access PIP menu. Go to any channel and hit the option button. You can then select multi-view.
Recordings work fine here.Definitely use live channels only, if you accidentally use a dvr recording, the sportsbar app appears to cause the recording to be corrupted and unusable.
I also haveU307
Sportsbar multiview,
Accessed via pip menu,
I can change each of the 4 windows to any chanel.
Audio dropouts about every 30sec on each of the 4 windows.
It's still not showing up for me...
It is not going to work on the Joeys. The 4K joey with have PIP (side by side) eventually.I tried this last night and it worked on the TV connected to my H3 but not my Joey.
DO you have a 4k tv? Does the picture switch to 4k in sports bar mode for you?Everything looking good over here!
Limited time offer
