Why ?
The S-Amoled still has it's issues in Direct sunlight. The EVO TFT LCD doesn't suffer as bad in direct sunlight.
Why ?
Check your PM Inbox
I could have sworn that the Xda member who ripped it advised against sharing that infor outside the thread because Verizon killed it twice already.
That's why I didn't post it publically I guess the fix is very easy, we shall see though
The EasyTether app rocks! Well worth the $10! I have been staying at my mother-in-law's place the past few days (will be there until Wednesday) and, you guessed it, no computer or Internet. As much as we love our EVO/Epic, there is only so much surfing you can do on a 4-4.3 inch screen. Anyway, no rooting required and it worked very well.I had the everything data plan with the EVO and was not able to use the Hotspot without paying the extra fee.
Yeah its not the best situation, but watching RedZone on a 4.3" screen while out and about isnt too bad. Plus since Time Warner doesn't carry it, I just hook my phone up to my TV via micro HDMI and its watchable. Not in HD of course but good enough.
The Swype beta I downloaded a while back expired...where can I find a version that doesn't expire? I would gladly buy the app, but they appear to be stuck on OEM. Even my wife started using Swype on her Epic.
It's in the The Market...just search for "easy tether". The free version (EasyTether Lite) is equally good...just doesn't support https, which I badly need. I recommend installing the Lite verision and giving it a try. As a guy in an old Alka-Seltzer commercial once said, "Try it, you'll like it."Where did you find this easy tether App or program ?
grydlok said:Just buy swiftkey you will forget all about swype. I have swype and don't use it anymore
Personally, I really like the Sense UI on the EVO. Plus, I have been extremely busy and the bloatware hasn't bothered me...yet. However, I will probably root the phone over the holidays. I would have probably "found" time to root the Epic if I had purchased that phone don't like the UIBig Dawg 23 said:If you want tethering why not Root the phone and use Barnacle WiFi for free.
Limited time offer
