Standard vs Universal ? | SatelliteGuys.US
sikma
the only difference between the Universal and the Starndard for the US is the Universal can get PAS9 (58W)
The Universal has 2 LO frequencies, 9750 & 10600.
Best non-universal I saw is a .5
If the old ones work. Use them! The feedhorn is made for the dish! If they are dead get another P* LNBF. If you get a new one the feedhorn will be round not ovel like the orig one. I use the orig on my 84E dish and it does OK.
If you have the orig lnb's I think a C-120 LNB will fit? Other please help me on this.
sikma said:
When looking to replace my old P* lnb's to pick up dvb and analog ku, does it matter if it's standard vs universal?
telesat americas 5
still can't get started
