star choice w/ pansat | SatelliteGuys.US
tpsball15
3
looking to set up a pansat with my star choice dish, does anybody know the settings for pansat? thanks
What settings do you need? The frequencies, polarity, and other specs are over at http://www.lyngsat.com
If you need Azmiths and Elevations you can find those at several places, or if you give a location I or someone else can look them up.
If you need settings for a motorized dish then you would need to look at the manual for your motor.
Other than that I can't help without more information :(
What satellite are you trying to get and what kind of starchoice dish do you have?
i would like to try and get the 107.3 sat. i already have it up and running right now, was wondering if the pansat receiver would work, and what freq. to set up with. i am using a 60cm dish w/2 non stacked lnbs. thanks
Okay, there is nothing at 107.3 that you could pick up with a pansat receiver. All the TPs covering North America are being used by Star Choice which uses Digicipher and doesn't work with a Pansat receiver.
Is there a particular type of programming you are looking to receive? There are about 25 other KU-Band satellites you could aim the dish at and receive.
