Starchoice question | SatelliteGuys.US
Starchoice question
stecle
378
219
Between the North and South Pole
I have a Starchoice Dual Stack lnb system. I was wondering if the Zinwell SAM 3402 3x4 multiswitch will work with my system? I want to add another receiver and the switch that came with my system has only has 2 outputs. I sincerely appreciate any assistance.
Steve
No - you need a 4X4 or 4X8 22 khz switch that passes signals up to 2150 Mhz
Here is the type of switch you need
SW44 4X4 FOR DIRECTV SATELLITE MULTISWITCH MULTI-SWITCH on eBay.ca (item 400090286363 end time 05-Apr-10 21:53:16 EDT)
You connect the output of the 2 LNBFs to the 2 low voltage inputs
Here is the exact Eagle Aspen 2x4 multiswitch that SD used for stacked systems
Eagle Aspen Multiswitch for Star Choice, 2 Stacked LNBF on eBay.ca (item 170384591686 end time 16-Apr-10 11:59:08 EDT)
Thanks for your reply! So to sum things up, I need to find a switch that has the capacity to switch 0 kHz - 22 KHz tones?
Thanks again
Steve
