StarNet TV/ How to Test LNB's | SatelliteGuys.US
Larry D.
10
Hi guys, I have a FORTEC L/T classic and Still trying to get Starnet TV (FTA) Channel, But no Luck I now have a 30 incher Primestar Dish, I retrieved from a friend, QUESTION <> It will work on a FTA receiver, Right?? as I have it setup it has a skew Adj, and Separate Vert, Horz, "F" connectors, ..i've only been able to get ONE Radio Channel,I have question about My LNB, The Sat finder seems to 'Say" the Dish is finding Sats, does this Prove the LNB is OK:confused: or no, it got a Radio Channel, I REALLY want o get this Starnet, TV out of Fla 1A7 I live at 30507 in Ga. Incidentially, how does this "129" degree translate to the TRUE Azimuth,Sorry for so many Questions, I DO have alot But having a Great Time doing it!!:D Som of You Gu Ru's Help Me get this Going...Thanks Larry KF4LKU
Moved to the correct area (out of the PC DVB area).
If you are getting one channel then the LNBF is working! Your Satfinder will ALWAYS pull you towards the stronger DBS satellites up there, you need to enter a LIVE TP./Channel in your receiver then watch for signal quality as you slowly point the dish!
What L.O. are you using in the antenna setup screen? Should be 10750!
Yep, Thats the right LO I have, and doing all You suggest real time, and looking for Sat's, Th area is clear of Trees etc, But seem NOT to "See'it
Just got myself a Pansat 2700a
StarNet Movies?
