Gr8Reb8 said:I do not watch SD anymore so I can not comment regarding those. The HD channels all look good today. The "stutter" problem remains on all HD channels I looked at today though.
GeneWildershair said:If you've got OTA channels on your voom STB, do me a favor and check to see if you get the stutter problem on those. I think this issue has a lot to do with the STB itself, as I can see the same exact stutter problem on OTA channels too!I'm starting to think that this buggy STB justneeds to be scrapped, and Voom/motorola just needs to design a better box!![]()
Sean Mota said:The stutter problem is there for OTA channels as well. It is not as pronounced as other channels but it is there.
GeneWildershair said:It isn't as pronounced as some, you're right about that. Same thing goes for most of the sd, and hd sat channels though, some are worse than others. Since it's there with OTA, wouldn't this then be an STB issue?
Videofx said:Went to 311 and CBS on my OTA, now watching HBOHD Breakdown and I can't see it. I all have seen was on BravoHD pixelization.
Bill
deeann said:Has anyone noticed an improvement or fix to the stutter since the software upgrade?
deeann said:Well dang, I'm not sure what to do then. I'd like to order it before the rate goes up at the end on the month, but I won't be able to watch it like it is right now.
ejm said:Just got my hookup last sunday. I initially was only using the s-video output to my analog Tv for viewing.
One thing I have noticed in my situtaion is that the stuttering would only occur when I was letterboxing the hd signal. When I changed to "squeeze" it would go away.
I then tried a soft reset by holding down the power button on the box for 5 sec, and now no longer experience the stuttering.
Sean Mota said:I changed to squeeze... Let's see if it changes anything.
Limited time offer
