SuperDish 105-Any uses | SatelliteGuys.US
cditty
1,293
35
Northeast Louisiana
I have one of these that I am not using. I do not have the lnb for it. Are there any adapters available for it that will allow me to mount a single lnb or something on the arm?
Is there any potential use for it or should I toss it. Seems like a big reflector to go to waste.
I got a bunch of these dishes new and used myself that I would like to sell that I have no use for. I know that they are good for FTA and for those that want a higher signal strength. I would rather not use them myself as they are harder to install. I have seen where they put a plastic W on the SuperDishes and converted them to a 1000 putting three DP eyes on it and using the existing DP-34 as that must have saved Dish Network money. Some people got a new dish instead.
The SuperDishes work very well as 500+ or 1000+ dishes. Great signal strength numbers with the big reflector. I am currently using my SD105 that I converted with a 500+ lnb.
Baltimore WMAR HD in SD
manual for the 20.0 and 21.0
