What does anyone use to mount a 121 superdish on a pole out in the yard, I cant seem to find the right size pole 2 inch ridgid conduit too big and 1.5 inch is too small??
Shawn95GT said:2" schedule 40 (heavy pipe) and 2 3/8" fence posts are the perfect size (2 3/8" OD).
Shawn
gireesh said:Go to any DishNet store, they will order you one. In Dallas, the store charged me $25.
What chain link fence people call 2" post is 1 5/8" OD, that is what I was told by fence supply stores in the DFW area.
HD and Lowes do not carry 2" O.D. They do carry 2 3/8", for the plastic Super Dish (Type 2).
Beg to differ Menard's/Home Depot and some times Lowe's is where the last contracting company I worked for bought theres for the longest time because of the shipping charges. I never bothered to ask if they were special order or not but I know there was a few times I had to go and pick a load up.Mike500 said:A 2" actual diameter galvanized steel post is easily obtainable at any dealer that sells commercial chain link fencing. It is not available at Home Depot or Lowes.
webbydude said:That may be fine for your system, but a superdish is really, REALLY touchy. Generally speaking, I will install them on a pole or roof mount with strut kit. It's just something about the FSS birds that make it a pain to keep properly aligned if set only on a 4X4 post
Kandiru said:Sorry guys but i had my DirecPC/TV(Duo) system (you should see how hard 1/4 degree alignments can be) for 5 years in rain and shine on a 10' 4x4 treated that i simply inserted into the ground using a fence-post hole digger and then trampled the ground around it (220 lbs fat by Ethiopian standards, just right here ).
Limited time offer
