SWN 3LNB Installation Help!!!! | Page 2 | SatelliteGuys.US
Success! Thanks for all the help - replaced all of my coax cables with high-quality RG6 cabelign and it was VERY easy! My receiver automatically found the SWM LNB and switch the settings internally - no additional programming needed. Wow - very thankful I did not buy a signal meter... ony guy told me "good luck finding the satellite without one" and wanted me to buy a Birdog. Thanks everyone.
Did you specify the correct dish setup? I get 213.7, 40.2, 69.8 from dishpointer.com when using the MultiLNB DIRECTV SL3. The numbers you cited in post #9 are considerably closer to the numbers for the Phase III dish (225.2, 36.1, 61.6).
I did use the SL3. For zip code 43212 it shows azimuth 231.1 (mag), elevation 35.3, and skew 62.2
HD-DVRs are soooo slow
Once again, SatGuys Saved my Bacon
