System Upgrade Help | SatelliteGuys.US
System Upgrade Help
xtraheat
15
I am looking to update my current satellite system. I currently have 2 receivers a DP 508 and a 301. I have dish 500 and LNB -DP Twin 1. I want to add another receiver and was wondering if it would be a major problem. Will I need a new dish or just a receiver? What would the additional cost be if I choose one of the following receivers:
625
322
311
Dishnetwork is running a promotion I think I can get the 625 for $119 and the other 2 for $99. The price includes installation. I asked about replacing the 301 with the 625 or 322 and they told me I can't use the special to replace an existing receiver.
I would think if the price includes installation, it includes everything to make the installation work, lnb's switches, etc.
dude i told you before call csr. if you do DHA 18. it will include the standard instalation. they might charge you extra for the 5th reciever install. since it will involved putting up switch.
How to get dish 1000 plus for KBS World
MAXHD Problem
