T-55 Dish With Motor. | SatelliteGuys.US
TheSage
4
I have a T-55 dish can i use a Sg2100 motor with this dish or which dish is good for this motor.......
I certainly would not recommend using this type of dish with a motor.
If you wish to use a smaller dish, consider the Winegard DS2076. Most people who motorize their dishes usually never regret using a 90 cm dish or larger to provide reliable reception of weaker services.
Closed this thread as Sage has already asked a Hacking question. As I said before if you PM any of the moderators with what channels you are legally trying to get I will reopen it.
The T-55 wouldn't really be able to pick up any KU band stuff, as it is basically a 20" dish
You need at least a 30" dish and KU LNB to get the KU stuff :)
Dish Size For SAN JUAN PR
I live in new york how big of dish will i need for picking channel from there i think they are on pas 1R....
Just doing a scan of Pas 1R. I think you will be best with a 90cm dish being so far north. Nothing found FTA KU band on that satellite, its very overcast here.
PAS9 and Mexico beam frequencies
Help w/ Atlantic bird 3 and Nile 101
