What grade of cable is it? What satellite are you talking about? What receivers (helps to know as some use dual feeds)
I have diplexed my cable and sat(dish) feeds successfully without issues, but never with FTA stuff so I can't report first hand experience there.
If it is RG6, then you should be fine. Now, check the splitter(s) used. You will need to change any CATV grade Splitter (5-1000MHz) to a Satellite grade splitter (5-2300MHz) with DC pass on all legs.
DC pass allows LNB voltage to be sent from the receiver to the LNB through the switch.I'm looking to do the same thing. What's DC pass?
Limited time offer
