chrisn said:He said it's causing problems and refused to do it. He told me to wait a couple of months (for updates) before getting the kit and hooking it up. Anyone know anything about this?
huh?
I've had my HR34 since February and its been hoked to the internet just fine
VOD is goofy (skips) but youtube works fine.
Is the HR34 the only receiver? If so you can hook up ethernet cable to it
I just had an install 2 weeks ago, and the tech hooked my HR34 to my router with no problems. I would call Direct and get someone to come back out.
Just plug it into the router. It can be direct connected and will provide connections to the other receivers.
Guess that tech doesn't like his broadband connection numbers.
Sent from my C64 w/Epyx FastLoad cartridge
huh?
The installer point of view = The FREE installation list has been growing. The money offered to install a much more complex system has remained flat in many areas. At the same time installers have, one way or another, been goosed to move through more jobs per day. So probably this installer just knew if he began the internet setup & ther was a problem it would cost him time he did not have,,,and wasn't getting paid to expend anyway.
Or he didn't know how.
Joe
How come I don;t have YouTube on my 34?
Limited time offer
