telesat americas 5 | SatelliteGuys.US
telesat americas 5
BIG_DUDE_4002
4
hi all tyed everything to find sig for t5 but i cant find it any help plz i have free to air receiver fortecstar lifetime ultra and here is the site that i found the same lnb what i have on ebay cant find the site anywhere on the net i only found it on ebay but its same lnb what i have
how can i post a link here about my lnb info if this site dosent let me
cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&category=61386&item=5769643664
LoL - that is the first Ku LNB I've seen w/o the L.O. right on it.
Here is the info from the ebay ad:
ebay item 5769643664 said:
Sat Sound Single Universal LNBF Model P1705 - ADTH
Universal signal coverage for American and Atltanic satellites, input frequency: 11.7 ~ 12.2 GHz, Outpur ferquency: 950 - 1450 MHz, Intergral feed horn with 40 mm neck.
Works with all KU band receiption . Great choice for Telstar 5, Galaxy 10R, Galaxy 3C, Telstar 6, and all other linear polarity satellities.
Light weight only 180 grams, can be easly rotated in clamp for fine tuning.
Made by Atlanta DHT Inc.
FEATURES:
Single Output LNBF Input Frequency Range from 11.70 GHz ~ 12.75 GHz.
Output Frequency Range from 950 MHz ~ 1450 MHz.
Various Input Frequency Range and L.O. for world-wide market Low Phase Noise for Analog or Digital reception.
Excellent D.R.O. stability Compact tooling.
Best solution for individual and multi-satellite systems.
Weather Proof O-Ring and Gasket inside.
Guaranteed Water Proof.
It says 'Universal Single' so 9.750 / 10.600 should work for your L.O.
Post your zip code and we can help you with dish pointing :)
hi
i live in canada ottawa ontario k1v 9s3 so in the reciver i set it up as Universal 9.750 what its the old ku lnb :)
Big Dude
Couple points I really need to make
-please spell out words....this isnt an instant message board. We have plenty of bandwidth to spell everything out...plus its a b*tch for some of us to read since we're old :)
-USE PUNCTUATION.... :)
If you are new to this stuff then get a standard LNBF and a meter. I wish I did. I have them now! I bet if you look around you can get both for under $30 shipped.
Good luck!
fortec star 120cm
Standard vs Universal ?
