What’s the cheapest setup for an RV I’ll be renting for two weeks. There are two TV’s and I don’t know how the wiring in the camper is set up. One RV is inside and the other outside.
to Satelliteguys Michael Bauker!What’s the cheapest setup for an RV I’ll be renting for two weeks. There are two TV’s and I don’t know how the wiring in the camper is set up. One RV is inside and the other outside.
SWM dish/Coax/ HR24
I've done this several times when renting one in a designated park we were staying at.
I've always brought my own equipment with me ... already working recvr from home, extra dish and coax.
In your case, if you use the SWM set up and 2 recvrs , you'll want the Power Inserter to power the LNB (Non SWM set up, doesn't require the PI.
Also a splitter for the 2 recvrs.
SWM dish/Coax/ HR24
If so, how do you plan on getting the equipment needed ?I don’t have sat at home. I’m doing this all from scratch.
SWM dish/Coax/ HR24
Good catch ... (Thats if you want HD)Don't forget non-SWM setups require a B-Band Converter.
No, not possible.It isn’t possible to by a used receiver and get a new card to activate something prepaid for a couple weeks?
No, not with Directv.It isn’t possible to by a used receiver and get a new card to activate something prepaid for a couple weeks?
Limited time offer
