Terk SIR6 + Sirius Connect + TimeTrax? | SatelliteGuys.US
  • Thread starter Thread starter rdtiii
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
rdtiii
I just got the TimeTrax pacakge (w/ Sirius Connect) and don't get any signal whatsoever. I get no feedback from the software whatsoever, even when I physically disconnect the dongle-thingy from the Connect-thingy. (I would have expected at least a "Hey, it isn't event hooked up!" message...
Anyway, I borrowed a freind's boombox and it works fine when I put the antenna in the same spot. I was thinking about getting a Terk SIR6 antenna to ensure I had a great signal and trying the TimeTrax solution again. But will the connector from the antenna fit the connector on the Sirius Connect box?
Thanks!!
Beta - 1.3.89 - Discussion and Info
Support / Upgrade question
