The Latest in Computer News | Page 12 | SatelliteGuys.US
Windows 7 SP1 mainstream support ends January 13 - will you upgrade to Windows 10?
http://www.neowin.net/news/windows-...s-january-13---will-you-upgrade-to-windows-10
Been using Win8 for awhile now with no issues like it better than 7 and been testing Win 10 like it as well they brought back the start button and did a way with the charm bar and disable the new start menu with tiles. So basically you stay at your desktop but you can enable it if you want it back but no need unless you want to run it on a tablet. But all the Apps run at the desktop now so you don't have to switch to the new start menu with tiles like you do on Win 8 so overall I really like Win 10 so far its like a combination of Win7 and Win8 all together. They will continue to patch Win 7 so you can still use it until 2020 but they will not be making any new features so if you want to run like Direct X 12 so forth you need to upgrade. I would recommend people to upgrade once Win 10 goes live this year to take advantage of the new features so you can take advantage of the new hardware coming out. You can do a upgrade from Win 7 or Win 8 to Win 10 XP,Vista you will have to do a clean install which reality no one should be really running anything older than Win7..
