Well looks like KLWB 50 in Lafayette moves to High VHF 14 and WGMB moves from 45 to 24.
RF14 is a UHF channel...
I almost have los to the channel 10/59 tower. I get 10 very reliably, 59 not so much.It isn't even up for debate I thought.I 100% know this from both the change to digital in Ct and Tampa. I can't even get channel 8 in Ct anymore. (Actual Channel 10) but get channel 59 from the same tower. (Actual channel 59) WTSP in Tampa had no problem when analog reaching it's market but after going digital they had to move to where most of the other towers are and get granted a power increase.
http://www.tvnewscheck.com/article/35850/digital-vhf-needs-a-power-boost
http://jackatcet.blogspot.com/2013/10/the-problem-is-not-in-your-set.html
I'm only about 10 miles away.It's the same here for me. 10 comes in fine always but 59 is usually not so good. I'm 61 miles from the tower.
thanks I forgot to correct it...That starts at 15....RF14 is a UHF channel...
Thanks...VHF low band (2-6)
VHF high band (7-13)
UHF (14-36)
For the stations who choose to take the money and shut down, when will they have to quit broadcasting?
One could logically assume that will happen when the station that was assigned their channel needs it. If the channel isn't reassigned (or negotiated for as part of the Second Window), they'll have to shut down at the end of the repack.For the stations who choose to take the money and shut down, when will they have to quit broadcasting?
Perhaps more importantly, discussions of personal reception issues should take place in other threads.Guys, you NEED to check your personal TVfool in cases where you can't seem to pick up co-located stations, that you feel you should be able to pick up.
"Kind of" The New Haven CPTV affiliate is hyper-local. Still keeping the affiliates in Hartford, Bridgeport, and New London.Looks like Connecticut is losing 4 stations.
Limited time offer
