The Worst luck with DiseqC switches. | SatelliteGuys.US
highskies
398
10
Texarkana
I have 3 of these that are 4-way. Before I got the third one, on the first 2, only one port would work. In the beginning, all 4 ports worked on both, but it gradually got to the point where there was only one working port on each. So I now get this third one, a brand new one at that. The Ebay seller who sold me my S9 recently, he included one of these. So I've had it for probably around a month I guess. Just like the first 2, all 4 ports were working in the beginning. But now I'm down to just one port working on this one as well. What in the world is causing this? Do these ports just randomly malfunction at some point without warning? Anyone else experience similar problems with DiseqC switches? This is not receiver related. I have an old Lifetime Ultra. I plugged that back in just recently, so I could see if any of the other ports worked on any of these switches. Same thing, just one port worked on each. Are these things pretty much toast now, or is there a way to fix this?
make sure you never unplug or plug in your coax with the receiver powered on....this can fry your switch....always turn it of with the rear switch before playing around with wiring....i use EMP diseqc switches and think they are the best in my opinion....mine are out in freezing cold all winter and snow and rain, and extreme heat in the summer and i have never had one fail....ever
I haven't had any Diseqc switch failures since I ran a ground wire to each of them, and put them under a weatherproof cover.
Also, I always shut off the hard power switch on the receiver before disconnecting or connecting any device.
Ummm...I can see one rule that I haven't been always following. Strangely enough, on my newest switch, I tried your suggestion and first turned off the box with the power switch on the back. I then hooked the CBand dish to one port, and the offset to another port, then turned the unit back on. I now have at least 2 working ports instead of one. But that's cool, because I only have 2 dishes anyway. From now on tho, I will no longer ignore this rule. I will always turn off the unit first, before installing or removing any coax cables. Thanks for reminding me. I think I knew this, but disregarded it some of the time, as much as I hate to admit as being that careless.
A little off topic but. . . . . .Wondered how to test one of these switches. Went to internet Google search with "testing diseqc switches." What pops up? First item > Satelliteguys.us and a post from 8/18/2007 by Anole on building a great testing device!
It proves if you want answers, this site has the people that know!
RT.
latest Openbox S9 firmware might be a keeper!
New to hobby; FTA questions
