5.1 is getting closer. Thanks to a tip at AVS Forum, I've confirmed on my Roku Ultra (2016) I can get 5.1 audio on network VoD shows on ABC, CBS, CW, and Fox. But not on NBC. I haven't had a chance to fully test on cable channels. Of course there's the forced commercial tradeoff. Fingers crossed that when it's fully implemented, it will include live TV and recordings of live TV.
What's odd is I couldn't get 5.1 on those same shows on my Roku Premiere+, also a 2016 model. So obviously still in a testing phase.
I tried the Roku 4 also and no DD 5.1 for network VOD. Messed with audio settings selecting DD 5.1 instead of auto detect and didn't matter.
All Rokus should be running version 8 of the Roku software so you shouldn't be seeing any material differences. You might want to do a manual check through the System menu to see if they're both running the same version.What's odd is I couldn't get 5.1 on those same shows on my Roku Premiere+, also a 2016 model. So obviously still in a testing phase.
One thing some may have noticed at least I have is Roku and Amazon Video have a lip sync issue. Seems to be common with all the Roku's I've tested (3) models so when watching Amazon Prime I switch back to FireTV.
I spoke too soon. I flipped my Premiere+ and Ultra (moved to opposite rooms), and now the Ultra (connected to my main living room system) is having the audio sync issues in the Prime Video app (connected to my AVR via HDMI), and changing audio settings doesn't seem to completely fix it, though selecting DD instead of DD+ helps a little. Seems to be a fairly common problem based on numerous threads in the Roku community forums. No sure fixes. Some say rebooting the Roku helps. Another one says to FF then RW. Thankfully my PS4 Prime Video app still works fine.
Yes, it's aggravating. I can fix by going into my Denon AVR and slowing audio down slightly but then everything else is off. Because Youtube TV still isn't compatible with Firetv I've decided to spend some extra and get the streamer Nvidia Shield TV so I'm not switching back and forth between Roku and firetv. My son talked me into it and wants me to play some RPG FF14 online with his group. I could never get into RPG's so doubt I'll go that far.
Also the CW stations live instead of On Demand. At least in the Mobile-Pensacola area.Now if they could just add the local PBS affiliates...
Limited time offer
