Thinking of getting DirectTV - Help please?!! | SatelliteGuys.US
LadyTrucker
2
Hello,
I am in Canada, just across from the ND border. I am looking at getting DirectTV HD PVR with Genie and wireless. Can anyone tell me if all this works in Canada?? I am specifically wondering about internet and worried about IP address.
Hello,
Ok,
Yes you can, however, I doubt that you'll be able to get a Genie, seeing they require a truck roll to put a genie in and they won't do that.
I would not connect the internet (thats just me) you do what you want ...
Technically, D* in Canada is Not available, that doesn't mean the signal stops at the boarder, thats said, it doesn't go much farther, if your truely just over the boarder.
Hopefully you have a US address as well.
If so, I would do your own set up after authorizing your recvr at your US home.
:welcome to Satelliteguys LadyTrucker!
As Jimbo noted, you would have issues getting a Genie as a new install.
Question about splitters for use with 2 swm64's
Coming Soon
