T Teryl New Member Original poster Jul 3, 2007 1 0 Mar 12, 2008 #1 Does anyone have a fix for this? Have tried re-setting several times. I have selected my time zone in the setup, it used to work fine, but since the time zone changed on March 9, 2008, it won't fix. Thanks.
Jimbo SatelliteGuys Master Lifetime Supporter Cutting Edge Jul 14, 2005 70,018 8,366 NW Ohio - Buckeye Country Mar 12, 2008 #2 You may have to go thru the initial set up, not a reset. This is not a common thing, but it may help, or you could call D* and they could reset it. Jimbo
jdspencer SatelliteGuys Pro Oct 22, 2004 4,088 18 Binghamton, NY Mar 13, 2008 #3 Are you in a location that didn't used to observe DST but now does? Also, what model DVR do you have?
jcrandall Proud Staff Member Staff member HERE TO HELP YOU! Apr 3, 2005 11,054 456 Central Michigan Mar 15, 2008 #4 I thought time zone was controlled by zip code during the initial setup? Perhaps try a different zip code in the correct time zone. It will not affect your local channels.
dfergie Proud Staff Member Staff member HERE TO HELP YOU! Sep 8, 2003 105,440 10,052 West of the Pecos, between White City and Roswell Mar 15, 2008 #5 http://www.satelliteguys.us/profile.php?do=editoptions> turn time zone to DST always on or Auto detect and try...If already on, turn off then exit cp and reenter cp and do the above...
