Timers skipping with PTAT | SatelliteGuys.US
satguyks
7
KS
I have shows that are set on the timers to record. When PTAT is on they are skipped and only saved to PTAT folder.
When I contacted support they said this is correct and I would need to turn off PTAT.
Are other users seeing the same thing? I would think there would be more talk it, if that was the case.
user: It does record in the PTAT folder, but then deletes after 8 days even tho there was a timer setup.
Kevin (ID: W7L): I know you can go into the PTAT recordings and select save on them but I'm not finding any info on the timers skipping. Give me a bit longer to try and find a good answer.
user: yea...But thats very manual, and defeats it uses? Plus what happes when your on vacation?
Kevin (ID: W7L): As of now that's how it's set up but you do have an option to disable the PTAT and set recordings if you go out of town.
user: Is there an official doc stating this?
Kevin (ID: W7L): No there isn't.
Kevin (ID: W7L): They are making fixes on the Hopper functions with updates so this may change shortly.
it says skipped, but it duplicates and saves it to your side of the DVR as well. Hopefully they took the suggestions from the main thread about it to re-label it in a future update.
the first time i tested it, i think i ended up locking up the hopper as i tried setting timers for 4 PTAT channels, watching two channels, and maybe even ondemand
What is the timer (not PTAT) set for - all shows, new shows, etc... is it following that maybe?
They are set to New only.
Take the show the mentalist. I created the timer on the 26th. A new show came on the 29th but never was saved. I was able to save it manually from the PTAT.
Then there is the show Body of Proof. It does work and it not show skipped in the daily schedule.
The Only diff I can see is the one woking has a Start and End time set. The rest have it set to 0. This should not make a diff?
MSG in Connecticut
PTAT question?
