Timetrax XM Online | SatelliteGuys.US
Timetrax XM Online
rsmith3400
19
Everything works fine for an hour or so, then I lose the volume on the VU level and all songs recorded after that point are black. The log show this entry: "Unable to parse stream address from page error code STR103"
Is it the windows xp firewall?
Try the beta version. (See the Beta Thread for more details)
It features a "keep alive" feature.
What is happening is the XM stream is being shut off by XM after "X" minutes and requires input from the user.
TimeTrax now takes care of that input for you.
Derek
Just installed 1.3 beta. Now no sound. VU bars show minimal action. Settings are still the same that made 1.2 work. Still have checked stereo mix on record control as before. Tried checking other boxes but no go.
Double check the levels settings and the device.
Open a ticket in our support system and we can work through a couple things.
I will have you send me a debug as well as some screen shots of your TT screens.
Derek
TimeTrax Recast Public Beta Program
MP3 encoding quality
