Titanium model CK1-S need part | SatelliteGuys.US
I have the LNBF only, I now need a scalar ring to be able to mount up to a 10 foot dish. Will any scalar ring fit? Or is there a specific one I need?
ANY C-band scalar ring that has a large enough center hole to fit it, will work just fine. The older thicker ones would be even better than the cheaper new thin ones, if you have around.
