Told I can't get Dish | Page 2 | SatelliteGuys.US
I installed computer networks for almost 30 years,so I have knowledge of running lines!!The lines would be a snap to run! I even offered to do it.I installed cable and C band lines in the same rooms. There would be 4 sets but only 2 dual tuner receivers. One would be in the master,the 2nd lead from that would be to the room next to it.That is about 15' away. The second receiver would be in the living room,with the lead to the second set straight above it,one floor up. There is already a hole for the line through the floor.Both main lines would go in under the windows,in existing ports.
If they came out for a line survey,and it passed,I have already agreed to the install.I also agreed to the OTA,so it would be a pretty good incentive for them to come soon. I am a serious customer,not a tire kicker!
Problem I don't know what to do about!!!!!!
dish store deals
