Transponder 23, Echostar 61.5 | SatelliteGuys.US
llenod
7
So I was flipping through channels one day and came across CSPAN2 on 212. I got an error with this transponder. I checked my other TV's with the same result. My signal strength on 24 was at 58-60. I called Dish and after some flow charts she sent out a tech. He arrived today and changed everything (Dish, arm, LNBs,)and same thing. He said he couldn't even pick up 23 on his meter, and my receiver was showing a signal strength of 12.
He called another tech in another city and same thing on his meter, he wasn't get a signal on 23.
So he concluded there is an issue on trans. 23.
Is anyone else not able to pick up this transponder?
~Nod
~Nod
It is very weak and undependable. Tp 19 not very good either.
You should had mention your setup in first phrase. We can't read your mind. :)
I'll check the signals later.
What we have on other coast (SF) using D500/I-adapter/DP LNBF:
01 SB (8PSK )
02 (8PSK 13.8 dB/52) ==============
03 SB (8PSK )
04 ?
05 SB (8PSK )
06 ?
07 SB (8PSK )
08 (QPSK 12.9 dB/53) =============
09 SB (8PSK )
10 (QPSK 12.8 dB/50) =============
11 SB (8PSK )
12 (QPSK 15.4 dB/68) ===============
13 SB (8PSK )
14 (QPSK 14.3 dB/60) ==============
15 SB (8PSK )
16 (QPSK 12.1 dB/43) ============
17 (8PSK 13.6 db/XX) ============== ( no services)
18 (QPSK 12.4 dB/48) ============
19 (8PSK 13.6 dB/50) ==============
20 (8PSK 12.5 dB/48) ============
21 (8PSK 14.4 dB/55) ==============
22 (8PSK 11.9 dB/54) ============
23 (8PSK 13.9 dB/51) ==============
24 (8PSK 14.8 dB/52) ===============
25 (8PSK 12.3 dB/41) ============
26 off
27 (QPSK 13.8 dB/58) =============
28 off
29 (QPSK 11.4 dB/50) ===========
30 (8PSK 11.9 dB/57) ============
31 (QPSK 13.6 dB/57) ==============
32 (8PSK 12.7 dB/45) =============
I added SS ("/xx") from 722 screen [L6.14].
722 spec question
For Those That Think Dish is Screwed Up
