Hi all...I'm new to the forum.
I'm considering a Glorystar system since I have Sky Angel and expect to lose SA when they make the change to IPTV (I have HughesNet satellite internet which IMO won't be fast enough).
A question on tripod mounting...I have the option of using a tripod on my deck. My understanding is that, using the universal mount that comes with the system, you can adjust the level of the post so that it is perfectly level even if your mounting surface is not. If I use a tripod like the one pictured in this post, I'm guessing that I would have to make sure that my deck is perfectly level since I don't think the tripod would allow the same leveling flexibility as the universal mount.
Does this sound right?
Thanks for your help!
