TSreader and VLC | SatelliteGuys.US
TSreader and VLC
tonydix
203
Bocas del Toro, Panama
I am experimenting with these 2 programs and I have a couple of questions :-
When I first used TSreader and locked a channel I saw a little thumbnail picture. Now I no longer see the thumbnail even though the channel locks.I have obviously inadvertently changed a setting !! Which setting ?
yesterday I used TSreader to record to the harddrive. It has recorded a large file with an extension bin.
VLC will not play this file . What more should I do ?
Thanks for any help
Tony
Look under "Settings" "Thumbnail Thread" and make sure "Disabled" is not selected.
If you select "Record Pids" you will get a bin file. Select "Record Program" and you will get a mpg file.
I havent tested, but if you are going to record pids, make sure you select
PAT 0x00
PMT, PCR, apid, and vpid
else vlc wont play them.
Viewsat 9000HD or Sonicview 8000HD
galaxy 19
