I have a Philips 47" LCD that has HDMI handshake issues. If I was to replace this TV to be used with a ViP 722k on HDMI which brand will work the best?
Thanks for input.
Thanks for input.
Thanks for input.
Not sure I want to use component since HDMI is suppose to be better.
HDMI is no better for video quality than component and if you use SPDIF for the audio you shouldn't notice any difference in audio either. Actually, component will often clear up problems that you have with HDMI.
What do you connect with SPDIF?
Digital audio out on 722 is Toslink (optical cable) also most modern TVs will also have that output to go to a stereo/surround receiver. It sends excellent stereo sound, but not capable of digital surround.![]()
My Samsung works fine. Just a thought... did you see if there is a firmware update for your TV?
Limited time offer
