It's not as simple as you think. I think it is a 2 phase motor. Better to keep looking for a complete unit. Ususally you can get a complete tower, antenna, and rotor just for taking it down yourself.
Channel Master sells a remote controlled inside control unit that works with most; if not all RS 3 wire rotors.(CM9537). It sells for under 40.00; plus shipping. Avoid the wire that CM makes for this unit. The RS wire is "much" better. I had to replace my wire after only 5 months.Anybody know what the voltage is to drive a rotor? Is it AC or DC. 12 volt?
Found a cheap rotor in the paper but comes with no control box. I can rig one up if I knew the output voltage of the control box to the rotor.
Thanks!
Limited time offer
