I had the same thing happen with my Wally on U810. I used the voice command "turn off" to put it into standby so it could take a guide download. Audio from the channel I had been on continued to play while the screensaver was on. After the number of minutes that it would normally take before the guide download starts, video from the channel returned along with a Wally logo and a "Please wait. Refresh in progress" message superimposed over the video. Then, it refreshed, returning me to Live TV. This only happened once, though. The next time I put the Wally in standby, it worked properly.After this update my Super Joey no longer stays in stand-by mode... When I put it into stand-by, after a minute it will start back up by itself.
I've tried to unplug it multiple times hoping it would fix it but it still has the problem... bad update?
I have lost the search function for "on demand" the look has changed, How do I search on demand now? The google assist is pretty much useless for searches.
I will give Dish credit where it is due. In the same software update that changed the look of the On Demand interface, they also moved the Search icon to the very first item in the Main Menu, making it easier to find.Hit Home twice and select Search.
If you hold down the Diamond or Double Diamond keys a menu will popup where you can designate that key to open SearchI will give Dish credit where it is due. In the same software update that changed the look of the On Demand interface, they also moved the Search icon to the very first item in the Main Menu, making it easier to find.![]()
And if you use a 40.0 remote, you can simply press the Search button.If you hold down the Diamond or Double Diamond keys a menu will popup where you can designate that key to open Search
Isn't that redundant to set one to stop, when you can press select to stop?And if you use a 40.0 remote, you can simply press the Search button.
On my 54.x remotes, I designate the diamond button as the Stop button, and the double-diamond button to open PIP. For the next series of remotes, Dish should either have more customizable buttons, or simply have more dedicated buttons for commonly-used features, just like the older remotes.![]()
Pressing Select brings up a banner, where Stop is not even the default highlighted option. Therefore, it is not even a quick double-tap of Select to Stop. You have to press Select, then press the right arrow, then press Select again. So, that is two extra button presses. The diamond button is only one button press, and it stops playback immediately. Pressing the microphone button and saying "Stop" is only one button press, but there is still a slight delay before the receiver responds. I have mentioned in the past that I still occasionally use an old 1.5 remote, solely because it has a Sys Info button to go directly to the Diagnostics screen, rather than have to press Menu twice or Home three times. If there is a way to save button presses to perform the function faster, then I will use it.Isn't that redundant to set one to stop, when you can press select to stop?
On the 54 remote after you press Select press the left arrow which wraps around to Stop. Press Select again. So three quick presses. Not ideal but works for mePressing Select brings up a banner, where Stop is not even the default highlighted option. Therefore, it is not even a quick double-tap of Select to Stop. You have to press Select, then press the right arrow, then press Select again. So, that is two extra button presses. The diamond button is only one button press, and it stops playback immediately. Pressing the microphone button and saying "Stop" is only one button press, but there is still a slight delay before the receiver responds. I have mentioned in the past that I still occasionally use an old 1.5 remote, solely because it has a Sys Info button to go directly to the Diagnostics screen, rather than have to press Menu twice or Home three times. If there is a way to save button presses to perform the function faster, then I will use it.
So, while you still had the 2TB drive formatted for the Hopper 3, did you try to see if the Hopper 3 would accept both that one and the 4TB drive at the same time? I still think the cap is a total of 7TB, rather than 7TB for each drive. This would explain why some people still report success using multiple drives (presumably with smaller drives, each under the old cap) while those who are trying the larger drives are having problems with the Hopper 3 not recognizing multiple drives.Well, I re-purposed the 2 TB drive I had been using for my Hopper 3 EHD, so there is no going back!
The 4 TB drive that was in the LaCie is now in the Seagate USB 3.0 enclosure and I can use that for another Hopper 3 EHD (but not at the same time as the 6 TB drive!).
Confused yet?
No, before I could get too creative I got a Remote Access call from work, so I got wrapped up in that instead.So, while you still had the 2TB drive formatted for the Hopper 3, did you try to see if the Hopper 3 would accept both that one and the 4TB drive at the same time? I still think the cap is a total of 7TB, rather than 7TB for each drive. This would explain why some people still report success using multiple drives (presumably with smaller drives, each under the old cap) while those who are trying the larger drives are having problems with the Hopper 3 not recognizing multiple drives.
Limited time offer
