SatelliteGuys continues to grow by leaps and bounds. Out of all of the Home Theater / Satellite Sites on the Internet we are ranked number 2 out of them all!
THANK YOU!
THANK YOU!
If you are a supporting pub member then you know we are working aggressively on our next big thing. And that big thing is another server upgrade!
Imagine if we took our current mammoth server and replaced it with a even faster server! Well it's going to happen!
We are proud to announce today that we will soon be ordering a brand new SatelliteGuys server which will replace our current server...
What's wrong with our current server??? NOTHING
Up until now we have rented our server, however for the first time ever we will be owning our own server! By owning our own server we will be able to reduce our monthly costs by almost 80%!
Besides the cost saving we will also be moving to a much more powerfull server. I am proud today to give you the specs of our new server.
CHIPSET
8132 HyperTransport, 8111 I/O hub.
1 64-BIT PCI-X 133/100MHz.
CPUs
2x AMD Opteron Dual Core 280
MEMORY
6GB PC3200 ECC Registered DDR.
8 Memory Sockets FOR DDR Memory.
Max 16GB DDR SDRAM Support.
CASE
1U Rackmount Case 500W power supply.
4 Hot-Swap SATA Bays.
FLOPPY/CD
Floppy and CDROM included with Chassis.
HARD DISK
4x 250GB SATA Hard Disk.
SATA Controller
4 Port 3Ware SATA Raid Controller
VGA
Onboard ATI 8MB VGA.
NETWORK
2 x Gigabit LAN Onboard.
The new server will be setup in a RAID 1+0 Setup (Raid 10) for maximum data security and speed.
In addition with the new server we will be moving our hosting to one of Americas highest rated ISP's. This ISP has many GigE Interconnects with most of the major backbone providers in the USA. These interconnects will make SatelliteGuys even faster for you!
Now while we will be upgrading we will not be rushing to do so however the upgrade is expected to be completed within the next 2 months. Our server Guru LER (Larry) and I will be working on the new server making sure everything is perfect and secure before we move anything over to the new server.
We will be ordering this server next week and will begin working on things once it arrives.
Also as of May 1st we will be doing some more changes to our forums based on your feedback and suggestions, we do hope you enjoy these changes.
We also have some more exciting things coming down the line but this new server is a big leap for us, one we are proud of. We hope you will enjoy it as we continue to improve SatelliteGuys for you.
Thank you for your support!
CHIPSET
CPUs
MEMORY
CASE
FLOPPY/CD
HARD DISK
SATA Controller
VGA
NETWORK
