updating softward for pansat 3500s | SatelliteGuys.US
neil_kc1
402
21
KANSAS CITY AREA
Anyone using the pansat 3500s? I am having some issues, seems to be off frequency sometime. Looked at pansat websight to see if they have new software. but looks like my software dated nov.03,05 is the latest. I wonder if I loaded the previous software would it be more stable? Ice you did i greaty review any suggestions. I have been and always will be legit. so this is not Hack talk. My current information on receiver is
Pansat 3500s
API ver 1.13N
boot ver.7.0
Nov. 03.2005
If you mean that you blind scan a satellite and your transponder frequency doesn't match Lyngsat, then don't worry about it. What is happening is the local oscillator frequency in your LNB is just a tad off of 10750MHz, or 11600MHz (whatever you are using) and it shows up in the scan.
If you're getting a good picture, don't sweat it.
what do you mean off frequency?
Some LNB's will have the frequency off by a couple. I know ONN (on SBS6) is at 11742 but mine always seems to log it as 11740 or 11741.
Or do you mean they are really off?
Radio missing from E* 119?
