Upgrading from 18" to AU-9/AT-9 | SatelliteGuys.US
Digital Logic
157
Norwalk, CA
So i researched my possibilities of upgrading and found a good deal. I currently have RCA receivers (DRD485RG/DRD430RG) and the upgrade brings in a free installation of a new dish
Im wondering if I were to upgrade 1 receiver, will it knock out my RCA receivers because of compatibility issues? I can only afford to upgrade one box a month for the time being and I dont want to have any issues with other rooms not working.
thanks for the help
Depend on just how old the receiver is. Does the setup menu for your receiver indicate anything about a 3 lnb dish, or oval dish? Does the signal screen indicate anything about 110 or 119?
ANyone else know much about the RCA receiver he mentioned?
and those on 119 are locals and some Spanish language internationals, which are not included in the normal packages.
Actually, there ARE a couple of the of SD channels on 119 that are PI's & therefore come with any package, as long as you have the appropriate dish/receiver - they are:
415-ONCE Mexico
438-HITN TV
D* even lists these on their latest ch list as coming w/Choice:
http://www.directv.com/see/pdf/chnl...1_A&_DAV=-1&_dynSessConf=-6620276031235982941
Does DirecTV Have a Current Deal with NHL Center Ice?
HDMI - DVI Cable
