61.5 satellite. mapped down to channel 9 on my receiver.What channel? Which satellite?
More junk added to the once nearly free TP. Just another indication Dish has little desire to do what they promised: use E11 to launch more HD.
Anyway, it's right next to the Obama channel on 5890. The future McCain Channel?
Thanks!61.5 satellite. mapped down to channel 9 on my receiver.
I'll trade you. I have just ABC in HD in Scranton, PA!
Is it?Now I need to run to the TV and see if this is real!!!!
Is it?
5150(16) - WNEP [MPEG4 HD] - Echostar12 61.5W TP 07 Area 6 beam changed to Available (H)(Scranton, PA)
What does the "H" mean?
I am watching it now!That is similar to my problems getting the wing some month's ago. DISH announced my locals in HD were available so I called DISH. Set the appointment for the additional Dish. The installer came out, then said he wasn't able to do the install. The CSR put in the order wrong. HD wasn't avail. despite the announcement. That's why I'd like someone to ACTUALLY see it in the Greenville, NC market before I call.
Uh, no. I just looked!
The SD feed still has the "sorry for the inconvenience" slate, and the HD version comes up with a "acquiring sat signal"
So now I have NO wnep!!
Anyone else in my area to confirm this?
It's in the legend on the uplink report at the bottom:
(H) = Hidden from non-subscribers
If you don't subscribe to the channel you won't see it in the guide at all.
I can't check right now because I have 2 recordings going, but this afternoon my SD feed still worked fine (I don't have an EA smartcard, so I'm not getting the MPEG4 one), and the HD version went to the acquiring sat signal screen and then went to the slate. Did you get a new smartcard? If not, I would think your receiver would still be looking for the MPEG2 version of the SD channels.
If you read the thread in the Pub a couple of weeks ago, it said that the signal wouldn't cover Clinton County and parts of Lycoming, Snyder, Union, and Northumberland Counties. It's funny that I get a signal strength of 6 on the spotbeam for Scranton and 67 on the one for Philadelphia and Washington when the only spotbeam map I've ever found has me on the edge of the one for Scranton (or wherever it's really aimed) and nowhere near the one for the other two! Evidently the spotbeam map was wrong. But now the question becomes, with MPEG4 why couldn't Dish put enough channels on the beams to cover all of the Scranton DMA, particularly in light of the fact that the parts they don't cover are the ones with the worst (or no) OTA signal.
Maybe the new HD channels will be launched on the first Wednesday in November - which is the day after the election and they could remove the Obama and McCain channels, and then use the whole transponder.
How can I tell where my dish is pointing too? Even if I don't have a dish pointed towards 61.5, I should still be able to pick up the channel in my channel listings correct? Because Fox 47 out of Madison is not showing up as a HD channel, but I should still be able to get this in the programming guide, correct?
So if I don't have a 61.5 dish, what are the next steps in order to receive my locals in HD.
Thanks alot!
Limited time offer
