Uplink Tool Change Log & Behind the scenes at the Uplink PC | Page 2 | SatelliteGuys.US
Nice answers, laconic ...
So, more come: ;)
- how the TSREader process automated ?
by deafult TSREADER creating files with names PID_0xYYYY.bin , when snapshots above shows totatlly different names; and it is non stop process and you can't read same time the PID files
- how often the script invoke TSReader and the SI tables parser ?
- what will happen if the batch/script somehow ( it is Windows !) will interrupted ?
concise...
Read up on TSReader command line interface.
Only one file needed. After all, it is a multiplex. ;)
As much as once every 5 minutes. More than that would be wasted effort.
If it breaks, it breaks. Same as rainfade.
That's really overkill - for 300+ KB of SDT and 40 KB of NIT collect whole mux, guess it's taking a few megabytes ... Would be easy to run TSReader twice for a couple minutes - one for NIT (0010) and other for SDT (0011), then load both files at one shot.
Digiblur - can you combine some of the 4 stickies into 1 or 2 stickies ? I used to be able to see the top new Uplink thread by just opening this Forum, but now I have to scroll down as well... yes, a minor thing, but some many things these days require our time that any little simplification helps.
