V-box77 wire | SatelliteGuys.US
V-box77 wire
pitmonkey29
29
What of wire do I need to run from my v-box7 to my dish actuator? And best place to buy it
http://pages.ebay.com/link/?nav=item.view&alt=web&id=281212517224
Commscope 8136 TVRO Ribbon Coaxial Cable (100FT)
www.gotcband.com if you need longer lengths.
I advise against using unshielded sprinkler wire as many have used for control/sensor function during the past few years and might suggest for your install. The open control and sensor wires often cause positioning and sensor errors. A shielded group with the drain wire connected to ground only at one end will provide much more reliable service.
Ty..the knowledge this forum has provided is invaluable as always!
Can Magnetizing Of A Steel Dish Be A Criminal Behavior?
Question about programming true south satellite into asc 1
