Video Problem | SatelliteGuys.US
Video Problem
zalarrulz
12
I just had voom installed and I notice that the picture was shifted like two inches to the left. I am using the DVI connection with 1080i. It happens on all channels. I didn't see this issue in the know bugs, but I might have missed something.
Welcome!
Is your TV set an RCA by any chance?
Try component and see if you still have the problem. Some TVs have issues with DVI - called the DVI "shift" problem. Has something to do with the timing of the DVI signal coming into the TV as I recall. It usually can be fixed with a firmware update for the TV.
Good luck,
Doug
How would you upgrade the firmware on a TV? It does not have networking capiblity or an input card.
OTA Channels Not Maintaining their “Hidden” Setting
Does the OTA tuner work without sat connected?
