Video Signal Issues: "Native" resolution | Page 2 | SatelliteGuys.US
desidoc said:
thanks sean what will we do without u, u r the mannnnnnnnnnn.....,
I am not getting any local channels is should be getting 2 channels atleast and i will try manual reset
Regarding your local channels. Compare what you are getting in your PG to the ones mapped here.
http://tvlistings4.zap2it.com/cabdbs/grid.asp?partner_id=cabdbs
the ones mapped shoud show up on your box. The ones that are not mapped, let me know.
looks like they have mapped LA channels to my receiver like KCAL and other LA channels and I am not getting any local, I have a stealth antenna
Which loca channels show up on your PG?
31.1
KVMDDT
36.1
KMIRDT
These are the ones which show up in the voom web site,
I tried connecting the cable to TV directly I get only ABC and the quality is just very bad
desidoc said:
31.1
KVMDDT
36.1
KMIRDT
How about your PG in the receiver? Anything shows up there? Which are you suppose to get?
I get LA channels like 4 NBC and 7 ABC and KCAL 9 and it says no signal
I just got my Voom installed but I can't get my RCA F38810 to lock so how do I change the output resolution on component?
-Peder-
-Peder-
It gets changed irregardless of the connection used by pressing the red button hidden behind the flip down cover on the lower right of the reciever.
Top bar flashing = 1080i, next down = 720p then 480p then 480i...all flashing = auto select.
Bill
