Viewsat extreme AC3 decoder? | SatelliteGuys.US
lavaboy
5
Would anyone know if it is possible to listen ( picture is fine) to the AC-3 dolby digital channels on 125W? I was wondering if one of the factory or hack files does it?
I have my extreme hooked up to an old Sony TV through an old sony VCR/DVD combo and do not have any S-pfid jacks on either.
I noticed another thread mentioned the Viewsat ultra file can decode the channels on 125W?
Also saw something about a sonic voom box to decode?
Would the newer receivers like Nfusion decode AC3? I have access to an Nfusion Solaris which I may just get for the pvr function?
P.S. Not sure how long has RTV on 83W been around? I never pointed at it until I got a motor last week, great Channel ( even though it has commercials).
I have one more question.
If I get a Dolby 5.1 surround sound home theater system can I plug my RED and White RCA outputs directly to the home theater box or do I need to use the SPDIF optical jack?
Lavaboy, I've had a sonic voom for quite a while and it works good. It pays to shop around for one if you can find it. At one time Ebay had them at about $20 or so. I think Amazon had it too...but you'd crap when you saw their price. Blind
DVBWorld 2104 and which processor?
Need a review and manual for i-link is-8000 fta receiver
