Viewsat vs pro won't move channels | SatelliteGuys.US
mroodey
22
I have a Viewsat VS pro that I just used to blind scan channels of G19. When I go to edit the channel list and click on the purple/blue button to move channels around I get no response (the remote lights up though to acknowledge that a button is pressed) . The buttons to lock, delete and rename channels bring a response but the one to move does not. Has anyone else witnessed this? Is there some special trick to moving channels with this receiver?
Hi mroody,
Did you ever get an answer to this question? I've similar problem on mine.
Naderro
Guys,
Just ran into the same problem. I poked around and figured it out. When you are in the Edit Channel List screen, press the Info button on your remote. This will pop up a menu. Choose "Sort by default", then OK. Now the purple/blue button will work!
40.5w Reception NSS806
invacom snh 031 problems
