ViP 722 audio settings | SatelliteGuys.US
Chimera
SatelliteGuys Guru
131
9
Hi guys,
I'm having some trouble with my new 722. When viewing tuner 2 via coax backfeed on channel 65, the audio seems to fade in and out especially when loud music is playing during movies etc. It's not a huge problem, just a little annoying but I'm wondering if there are any settings I'm missing that would solve this issue.
Grahame
Sounds like it could be a cable problem. Would it be possible to try going directly from the 722 via short coax to the TV that is right there beside it? If the problem still exists then it is likely a problem with the receiver, but if the problem goes away, you likely have a problem with your cabling between the receiver and your TV2.
I'm not sure it's a cable problem, to me it seems more like a 5.1 compressed down to 2 channel problem, as it happens mostly with the HD movie channels. I just didn't know if there were any audio settings I could change that affect tuner 2.
Sound "Squelch" and picture hiccup
first post
