VIP211 Local Sat Channels Map down | SatelliteGuys.US
sparkstsa
7
I have two vip211s that are experiencing the same problem. On both I have local sat channel map down enabled, but there are no channels appearing below ch. 100. I can see them in their 4 digit channel range. They are chattanooga locals starting at 7330 and two of them are in hd at channel 5151 and 5153. Anyone know how I can fix this?
Tried that... plus the 2nd vip211 is brand new... wouldnt map down at of the box even though it was already set to.
Disable remapping, cold reboot - check guide, then enable again, cold reboot - see the guide
sometimes your changes not stored in NVRAM by unknown reason
ok so for Dish HD channels I selected "disable" and I held the front power button down for 6 seconds and am rebooting now.
Ok... I have no luck getting locals to map down on my vip211s. They are not mapped down on my 2 sd receivers either. Maybe its something to do with chattanooga locals, I dunno.
So who is lying, E* or local Salisbury networks?
Inline Amp and How to Get The Placement You Want Recommendations
