mikbro said:You were right about the image quality - at the highest recording quality in SageTV (higher than the highest supported by MCE) you do get DVD quality and with the Voom boxes ability to squeeze/stretch you can record widescreen content "anamorphically" to get every last drop of image quality.
mikbro said:SageTV is also worth a look - it has the Voom listings, supports multiple tuners (I have my 3 voom boxes connected to it and capable of recording 3 things at once). It also allows for me to connect analog cable or other providers. MCE limits you to 2 analog tuners and 1 OTA HDTV tuner, and you can only have one "source" (ie Voom) defined for the analog tuners.
It also allows you to have both the OTA listing and VOOM listings merged into one guide. A necessity for me.
VorpalBlade said:Can you elaborate on using anamorphic settings on the STB to improve Sage captures? I've just started using Voom and am trying to improve my Sage recordings as much as is possible.
VorpalBlade said:I had an hour or so of panic until I figured out that I could define the coax vid out as one source and s-vid as another. Once I got that done, Sage merged them both together in the guide.
Some cards may not have multiple inputs or support defining seperate inputs simultaneously, which would mean Sage would not be able to include both locals and Voom programming in the same guide.
philhu said:I looked at SageTV. I like it
I was looking at bundles. What is the convertx box they talk about.
I do not see an advantage of that over the hauppauge cards.
Any ideas what the difference is?
And, how many tuners can you put in the sage box? Can you do a pvr-500 (dual tuner) and a pvr-250 to get a third stream? Would it integrate 3 guides in the listings?
If so, I could do Voom, DTV AND cable box, all in one box, which would be cool
mikbro said:The Convertx box is a MPEG-4 encoder - the Hauppauge cards are MPEG-2. The advantage of MPEG-4 is you get *roughly* the same quality but take up a lot less hard drive space. If your ultimate goal is the best quailty recordings - go with the hauppauge cards. The PVR150 is a great card for the money and you can run several in one box. If you run out of PCI slots on your motherboad you can also use their USB2 encoders at ~$130-$150 ea.
Each input on each card can have a different guide source - and they are all combined transparently into one guide and used for conflict resolution when you setup your favorite shows to record. SageTV is available for a free download eval so you have nothing to loose. Keep in mind though that you are building PC that ideally has a 24x7 uptime and that your choice of hardware will factor into exactly how stable it will be. You can find a lot of information on SageTV's forums and in their excellent user manual.
I used to have a business building and selling HTPC PVR's based on SageTV software so if you have any questions on the best hardware to use pm me.
I believe the retail kits for both ship with the same remote control - the retail kit for the PVR-150 also includes an IR emitter - though I have not tried to use it with SageTV. For channel changing duties I would recommend the USB-UIRT - it has native support in SageTV and can be used to all the devices in your system (Voom, DirecTV, and Cable).philhu said:Great reply.
Can I buy the pvr-150 bundle with the remote? Or would the PVR-250 work better? Also, one card will get svideo from the voom box and one will get svideo from dtv and the third card will actually do tuning of the cable box.
The encoder will record full screen whatever you throw at it... when you playback you can alternate between "Fill", "Source", "4x3" and "16x9". In your case when you record 16x9 content from the VOOM box (and set the Voom box to Stretech 16x9 content so it takes an entire 4x3 screen) you would play it back in SageTV in the 16x9 AR. Since this is a playback setting and not a recording setting you can alternate any recording you have made between the ARs I mentioned with the press of a button.philhu said:Can you set the letterbox properties per card or is it system wide? I want to use the voom stretch/sage letterbox for that card/svideo, and not use it for the rest.
Yep - with the USB-UIRT I mention above - there are menu options to teach it the VOOM buttons same as you would for your Directv and cable boxes.philhu said:And finally, does sage control a voom box? I know the bundle contains an ir sender to control other boxes, but can it do a voom box?
mikbro said:Yep - you would need another tuner card in addition to the one in the bundle. It seems like SageTV does support the IR Emitter included with the package. The only downside to it is that it only has one "emitter". This would need to be located somewhere when it can shower all of your receivers with it's signal when it changes channels. The USB-UIRT comes with a built-in emitter (very poowerfull) but also has a connection for you add an additional emitters (2 more actually with a splitter) so you can have emitters taped directly to your equipment for more reliable channel changes.
Threv said:I have finally built the my media center PC and everything seems to be OK except that I can't get the Media Center remote to change the channels.
I have done the setup (both automatic and manual and still no luck)
any advice or hints (and no don't tell me to get SAGE thanks!)
Limited time offer
