[VOOM/DISH/OTA] How to Set Up a VOOM STB for OTA Digital | SatelliteGuys.US
B
bgrodie
Guest
I just posted these instructions over at the Satellite Forum since
some members have picked up VOOM receivers off ebay, etc. recently.
I hope they are useful to some of our newer VOOM forum members who
joined because they purchased a VOOM box:
If there is an OTA module with an F connector on the back of your
VOOM box you will hook it up there. The module will be on the right
side of the rear panel and can be identified by a light grey plastic
tab which is a quick release button.
I do not recommend hooking up the OTA antenna while the unit is
powered on and to be very safe I would hook it up before it is
plugged in. Since you are going to use a splitter if you are
keeping your other sets connected, I would recommend that you buy a
DC block for coax at Radio Shack and use it between the antenna coax
and the VOOM box. The VOOM box does put out a voltage from the OTA
module and it's probably best not to impose that onto the rf inputs
of your other TV sets.
When you are hooked up and powered on and the Monitor is also hooked
up you should see a screen with The VOOM logo and a please wait type
of caption. If you don't you can try lifting the flip cover labeled
Motorola on the right front panel of the VOOM box and pushing the
button in that compartment, waiting a few seconds and repeating it
until you get a picture. You are toggling the output of the box to
match your monitor. You may notivce that amber light bars will go
on and move as you do this. All four light bars may also come on
indicating native resolution. If you have no picture anywhere in
this process recheck your wiring. If you have a picture you are
ready to use the "scan locals" function.
1) Push the big VOOM button and it will show theme basedprogram
guide type of ID page.
2) Push the Green round button in the third row of the remote to
select "options and settings".
3) Again push the green button to get to the "Systems Settings"
screen.
4) You will get a warning notice and is with all warning notices go
ahead and ignore it....just kidding, only ignore this one.
5) Now you are on the "Systems Settings" page and there are a few
setup items to select. For now, select Option 7 "Installer Menu".
You can "play" with the others later.
6) Choose Option 1 "Installation Wizard".
7) You can choose "Option 3" to aim your antenna if you have a rotor
or skip this step if you do not have a rotor or feel your OTA
antenna is peaked.
8)Choose "Option 4" "Scan local channels" and wait and watch while
the receiver is finding and listing your digital locals.
9) Choose "Save and Close" or "Redo Aim" in the case that you don't
find all the channels that you expect. If your antenna is hooked up
correctly and has a good, stable signal you will scan in all your
Digital locals.
10) Now hit the "Watch" button below the VOOM button and go to 100
by manually entering the three digits and hit OK button.
11) Now use the channel selector on the right side of the remote
and channel down. You should find the channels that you scanned in
here in the channel numbers under 100.
There will be no Program Guide since the VOOM service beamed that
one in via Satellite.
Watch and enjoy. It's a very good picture. isn't it?
Yahoo! Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/VOOM/
<*> To unsubscribe from this group, send an email to:
VOOM-unsubscribe@yahoogroups.com
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
More ota info
I have an antenna left from the Voom install and would like to see my locals ota from that antenna. I have switched to comcast since the death of voom and my locals on it are poop. How do you split the dvi sig between voom box and a cable box? Or do I get the signal from the voom box into my TV via coax or rca's? I like the dvi input but my tv only has one.
You need what's called a DVI switch. I just bought a Gefen HDTV DVI 2x1 Switcher. It comes with a remote control and two DVI cables. The lowest price I found was $219.00 (with shipping - $233.61 to San Diego from New York) from www.KVMGalore.com Be sure it is the EXT-HDTV-241 and not the EXT-HD-241 which is HDMI and not DVI.
There are really no any other solutions except buy a newer TV with multiple HDMI inputs (DVI is now obsolete) or buy a receiver with DVI or HDMI switching (fairly rare yet).
[Non-text portions of this message have been removed]
Yahoo! Groups Links
Gefen appears to make some really cool stuff but I recommend that you consider using the component output instead of DVI. It's a LOT cheaper! :-)
----- Original Message -----
To: VOOM@yahoogroups.com
Sent: Sunday, June 19, 2005 9:40 AM
Subject: Re: [VOOM/DISH/OTA] How to Set Up a VOOM STB for OTA Digital
Yahoo! Groups Links
a.. To visit your group on the web, go to:
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Yahoo! Groups Links
Yes, component is cheaper, but DVI gives you a sharper picture with microdisplay (no advantage with CRT) and you can get an upconverting DVD player like the top-rated OPPO which beat DVD players costing mega-bucks. See the review at www.audioholics.com . See www.oppodigital.com and www.extremephono.com . Spectacular PQ.
Use the money you save on the OPPO to buy the Gefen DVI switch.
Yahoo! Groups Links
B
RE: [VOOM/DISH/OTA] Dish 942 records 2 local hd channels simultaneously
T
[VOOM/DISH/OTA] Re: Voom only pick up part of PBS
