[VOOM/DISH/OTA] Re: Voom on Dish | SatelliteGuys.US
  • Thread starter Thread starter jimc705
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
J
jimc705
Guest
--- In VOOM@yahoogroups.com, "gtata" <gtata@s...> wrote:
> I currently have Dish Network service but would like to get Voom
> channels. I got a Single LNV DirectTV dish and would like to know if
> this will work with my Dish Network system?
> George T
George,
The answer is maybe. The Direct dish will definetly work. The LNB
will work if it's the old external switch type and not the newer built
in switch. The Dish system must also be the older external switch
type. They are known as Legacy LNB's.
So if both are the old external switch type then it will work. If
either are the newer built in switch type then they won't. Dish Pro is
on the LNB anywhere then it's the built in switch type. If both are
the new built in switch type then probably but not sure.
B
[VOOM/DISH/OTA] Conversion to Dish issues
B
Re: [VOOM/DISH/OTA] Dishnet installation-4 orbital locations needed
